-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   1998 Baja 232 Islander toggle switches (https://www.offshoreonly.com/forums/baja/224236-1998-baja-232-islander-toggle-switches.html)
Ebay Ed 02-12-2010 10:50 AM
my memory wire which is a small yellow wire must run to the toggle switch along with the 12 volt feed wire for the radio because when you turn off the toggle switch for the radio i loose everything
Irishtornado 02-12-2010 12:17 PM
Need to wire it to constant power like your cig lighter that should be right there.
bajarick 02-13-2010 07:20 AM
Look at battery switch you should have two wires
with fuse connectors , one is the radio power to
hold the memory , the other wirer is for the bilge pump
in the cuddy if you have one.
Rick
mittens 02-16-2010 08:52 AM
Rick
I will ahve to check this out when i unwrap it fomt he winter. is so maybe mine has a blown fuse, will make me happy to not have to reset it everytime i put the boat in the water.
