-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   What size are the cup holders in the Baja's? (https://www.offshoreonly.com/forums/baja/227983-what-size-cup-holders-bajas.html)
bajaboatnut 04-08-2010 02:06 PM
Trying to order some from eddie marine and not sure if the baja's have 3 inch holder or the bigger one. I'm thinking off hand boat is away right now I need 8 for my 29
boogy886 04-08-2010 02:36 PM
2 different sizes probably...My hammer has 2 different sizes and I've got a buddy with a 25OL that's got both sizes as well
Here's the most helpful thread I've found on it, and it's not much help...
http://www.offshoreonly.com/forums/b...p-holders.html
Baja_342 04-09-2010 11:14 AM
You need the large. They are all the same size.
http://www.eddiemarine.com/store/car...l&p=12278&c=82
BajaFresh 04-09-2010 02:12 PM
I replaced all of mine with the aluminum ones except the front passenger one. The grab handle is in the way. I can get the old plastic one out but not the new one in. I'm going to have to remove the handle but it is blind side mounted and I haven't gotten to pulling the panel off to get to the mounting screws. :(
indywhsle 04-10-2010 06:04 AM
I changed all of mine and didn't have to remove the handle. If you get the large ones you will have to make the existing hole bigger. I shaved enough (toward the radio) to get the new one in. The rim at the top covers the entire area. It was tight but doable. Hope this helps.
bajaboatnut 04-10-2010 09:40 AM
Indy did the large ones work for all 8
indywhsle 04-10-2010 12:42 PM
Yes all 8 are the large ones. Just have to make the existing hole a little bigger. That is the only option. The next size down is too small.
bajaboatnut 04-11-2010 12:34 AM
thanks
JasonSmith 04-16-2010 05:55 PM
You gotta tilt the cupholder in the hole to get it out. I can take mine out & it is trick, but it will come out without having to remove the handle. Unless your handle is just mounted really low.
HOSSMAN 04-16-2010 06:04 PM
Where the He!!'s the color chart! There are 3 blues and lime green. Do I do blue..blue or blue or lime green in my 29??? Suggestions? (boat is blue and lime)...oh and gauge bezels...lime or chrome?
