-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Lets talk gauge wiring. (https://www.offshoreonly.com/forums/baja/228045-lets-talk-gauge-wiring.html)
JasonSmith 04-09-2010 05:28 PM
The purple wires are tied to the blue wires (purple being ignition & blue being lights)
When I stick a continuity meter on the ground it says there is continuity between the ground, purple (I) & blue leads (L). That doesn't seem right to me.
Should I not be Bud Lighting it while on this project?
I think I hooked everything back up the way it was, but I'm not sure now.
US1 Fountain 04-09-2010 08:43 PM
If the bulbs are in, you'll see continuity between ground and hot. Guess it depends on which side of the switch you are testing.
