Sea Strainer for 25 Outlaw
I bought a Livorsi sea strainer last year and am just getting around to trying to install it. It ended up being a lot bigger than I had envisioned and I am having some trouble figuring out the best place to install where I can still plumb to it.
Anyone else have a 25 Outlaw, or similar package, that can offer some advise and pictures of where yours is installed?
(I tried to attach a photo; but, when I click the 'Insert Image' icon, it asks me for a URL address; what's up with that?)
Thanks,
Mike
Thanks,
Mike
I have a 232. A very tight fit as well. I mounted mine above the stringer on the side. 232 has the flat part from side of boat and does a 90 down to bottom next to stringer. Shot hose from strainer to pump. works very well.
I used to have a 232 and am familiar with the flat area; the 25 Outlaw has the same. So you mounted yours on top of that flat area? Have you had any problems with the seawater pump pulling through it? Any chance you might have a photo you can post showing which fittings you used and the hose routing?
Thanks, Mike
