33 Outlaw help..just bought one!!!
Hi guys
I just traded my 1988 265 Force for '99 33 Outlaw...I have a couple questions for you....the '99 has 454 Mags..Bravo 1's, in it ..completely stock, with 25 pitch mirage plus props...I bought a prop for my '88 265 from the "cutting edge" prop guy but now that my 265 is going away..I will not need that prop so cutting edge will take it back..but i would like to get another set of props..so what would you all guess with my power, that I would run for a set of 4 blades..anyone have same setup?..I may ask him if he can build me a set of 4 blades with less than 26 pitch..I am just not sure..any help is appreciated..also, how should I expect this boat to handle with what I have for power and props? thanks guys |
Call Brett at Bblades.
When my 2000 had stock 502 mags, I turned 24 Bravo 1s.
I would expect that you may need 22s, or to have a pair tuned to 23s. Best thing to do is to put a set on, and see what rpm you can get out of it, and go from there |
Thank you...pwam1...that helped alot!!! Out of curiousity..what kind of numbers did you see with the 24's on.
Thank you...pwam1...that helped alot!!! Out of curiousity..what kind of numbers did you see with the 24's on. With two people and 100-125gal. I would run just under 70. |
I had a set of Bblades 26 bravos on my 2001 with 496 Mags.
I think the 2001 models had a different X dimension..not sure if that would make a difference on the props or not..so eddie, how was the performance on yours?
Thank you for your order! Glad I could help! We'll get that new set built ASAP when you get me those run numbers.
Greg Hittner, CUTTING EDGE PROPELLERS
Originally Posted by Bajapred
(Post 3093035)
Hi guys
Thank you Greg..I dont pick the boat up until May 1st..so i would say give me until middle of May to get all the info I need and get back to you with it. looking forward to it!
Scott |
Stay with 3 blades,your x dimension is too low.
| All times are GMT -5. The time now is 12:30 PM. |
