Help please >
Help please
Help please
Old 05-22-2010 | 03:40 PM
Default Help please
Had my starboard motor pulled for some glass work. After picking it up after the work was done and motor put back in I have no bilge pump or blower. Fuses are good. The switches light up when on and a constant buzzer from the dash area sounds for each one as well THanks for any help.
bajaboatnut is offline
Old 05-23-2010 | 08:09 AM
Bill 3's Avatar
My guess is that they were probably unplugged back in the bilge. Probabaly put together with "bullet" style connectors back there.
Bill 3 is offline
Old 05-24-2010 | 10:10 AM
Custom Interiors & More
Robert,
Hey, the buzzer is not related to a problem with the bilge, or blower. Check the floats in your drive oil bottles to make sure they are not stuck, and that you have gear lube to the fill line?
XT-Innovator is offline
Old 05-24-2010 | 10:50 AM
Dock Holiday's Avatar
Charter Member #34
Yes check all the electrical connects and grounds.
As Dave mentioned the buzzers are probably the drive fluid bottles.
It should all be an easy fix, check check over everything very closely.
Dock Holiday is offline
Old 05-25-2010 | 08:34 PM
Thanks guys ended up being the ground, ready for the holiday weekend now and the bay. Hope everyone has a safe and enjoyable wkknd
