272 problem with J Hooking
You've got some loose/ worn out parts back there and that is a bad combo to have with that much power and speed.
move the drive side to side, if the wheel doesnt move right away there is something worn
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Custom Interiors & More
Did you happen to upgrade to a 4 blade Bravo 1 propeller, and you used to have a stock 23" Mirage Plus? I have experienced that when you back-off hard on a 4 blade single engine setup, it feels like you just deployed a peracute, compared to a 3 blade????
Think of it in simple terms, when you suddenly stop a right-handed prop, the lowest blade below the driveshaft is now a "rudder" that kicks the rear of the boat to the left!
XT
XT
Replace the gimbal pins & add a single ram hydraulic steering system atthe very least so you don't hurt yourself.
You will get hurt too if you don't fix it correctly. I'm pretty far from the safety patrol guy but I've been in your exact situation with my old 226es.
I added a single ram add on steering system from WPM. It helped tremendously & is the least you should do after replacing the worn parts.
