-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Need a little help with my "new to me" 272 (https://www.offshoreonly.com/forums/baja/232761-need-little-help-my-new-me-272-a.html)
hanzcap 06-15-2010 02:33 PM
I recently purchased a 272 with a 454 magnum. I was told the boat runs about 59mph. The question I have is what kind of RPMS should I be seeing at WOT. I have only taken it out once since I bought it the previous Monday and I did not have my GPS with me. The previous owner said the gear ratio in the drive was 1.36:1. I want to say it had a 23 pitch mirage prop. Thanks in advance for your help.
rlong 06-15-2010 09:05 PM
How much HP mine was a 415 HP 502 i never GPS but speedo showed 63 i was running 25 pitch?
Ebay Ed 06-15-2010 10:25 PM
i have a 310 hp 454 and i have gotten 58 on my gps i would guess you would be slightly over 60 with the magnum
joe27baja 06-15-2010 10:32 PM
hey what year is that 272 you picked up
obnoxus 06-16-2010 01:30 AM
max rpns depends on what motor you have,
I am guessing a 454 if its only a 58 mph boat.
it would have to be an early 272, or the drive was swapped to be a 1:36 ratio
the boat would perform better all around with a 1:50
What year and motor do you have ?
Dock Holiday 06-16-2010 07:24 AM
hanzcap,
Welcome to the site and congrats on the purchase of the 272. It is a nice boat that I'm sure your will enjoy.
Very strange for sure that you have a 1.36 ratio drive. They all came with 1.5 from the factory which is more of an industry standard ratio for a boat like yours.
Here is a link that will help you. If you put in your drive ratio, prop pitch, max speed and estimate your slip between 10% to 15% it will show you that your max RPM is between 4000 to 4200 RPM. This seems low to me as I think that motor can spin up to at least 4500 RPM.
http://www.rbbi.com/folders/prop/propcalc.htm
Good luck and I hope this helps out.
Mark
hanzcap 06-16-2010 08:14 AM
Thanks to all those who replied. I picked up a 1995 272. The boat is immaculate and was in the price range I wanted to spend (paid cash). The motor is the 385 hp version and has after market exhaust system by Stainless Marine out of Florida. I was told the drive ratio is 1.36 by the previous owner who owned the boat since new.
