-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   25OL..Stellings Box..IMCO shorty.. (https://www.offshoreonly.com/forums/baja/232993-25ol-stellings-box-imco-shorty.html)
Baja_man 10-05-2010 08:24 AM
Originally Posted by Fixxxer22 (Post 3222973)
with your X higher now its really of no use. mabye you could sell over the winter and try and get another 24p bravo to get worked on. you need a 4 blade for your application now. i spin a 24 4 blade as well for all around use. it has a harder time carrying the bow and the boat only runs about 70-71 with it at 5600 rpms.
I use a labbed 24P B1 99% of the time with the 23P M+ as a spare. The B1 is at Bblades now getting re-worked. I agree the M+ is not even close to the right prop which is why it is just a spare. As long as the other uprades pan out this winter the 23P will truely be useless and it will be yours and I'll get some new spares.
Baja_man 10-05-2010 08:25 AM
Originally Posted by jeffswav (Post 3222895)
I think he posted 3" with the raised box and shortie. Not sure if that accounts for the drop with the 12" setback.
It is 3" currently at the nose cone.
Baja_man 10-05-2010 08:31 AM
Originally Posted by AIR TIME (Post 3222843)
I have a queston so with the shortie you were at a propshaft height of 4'' is this correct ?? if so don't waste time with pulling it off do your up grades and then go out try the 26 which you need 500 hp to turn at 5200 to 5100rpm
It is 3" and I think too high....It needs to be at 4".
I should be in the 560-570 HP range with upgrades and really don't want anymore than that due to the Bravo 1X limitations. If I could get upper 70's with that set-up I'd be happy. 80 I believe is out of the question with just 560HP.
jeffswav 10-05-2010 06:55 PM
Hopefully you can try your Bravo prop before the season is over. I would think 3" would work with the right prop. Good luck with your testing!!
AIR TIME 10-06-2010 08:25 PM
alright your at 3 wait do the motor work and try a 26 check your numbers then put a 1'' or 1/2'' spacer. the guy with the 25 ol tried going up 5'' with a 3''box and 2'' shortie he added a spacer of 1'' and was happy. but I for get if he ended at 3'' or 3 1/2'' so try it 1st after the motor work and if not happy then move down.
