24baja with 700hp >
24baja with 700hp
24baja with 700hp
Old 11-02-2010 | 10:11 AM
AIR TIME's Avatar
Originally Posted by cowboy5214
I also just bought a 240 sport super clean 300hrs has a 550 stroker dyno at 600 hp the guy that built it said to have my heads done he can get me 750 hp but the boat already does 78-79 mph and that's running a bravo 1 and a 24 pitch prop at 5600 rpm boat was dynoed at 6600 rmp but we turned it back to a below safe area it will handel 6600 but did not want to push it that hard
wow is that gps or speedo? if its gps and a 1.50 gears thats 7% slip which is great, the best I got was 13 to 15 % with mine running a b1 26 at 5900 to 6000 rpm got 83.
AIR TIME is offline
Old 11-03-2010 | 04:53 PM
Are those GPS numbers? Sounds like you have it running pretty fast. Did you raise your x dim?
jeffswav is offline
Old 01-05-2011 | 03:24 AM
it will if it is smooth water not to bad though I have full hydrolic stearing I noticed in your vid that your was chime walking a little
cowboy5214 is offline
Old 01-05-2011 | 07:50 AM
FWIW Pretty sure the thread starter is now banned from OSO
drpete3 is offline
Old 01-08-2011 | 04:56 PM
yes i had a little chine walk . i do not have full hyd steering. i had air in the cly. talk to imco and i need to go full hyd steering . i looking now for the helm and lines.
bajabob is offline
