-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   wt the best prop for a 272 with 600hp (https://www.offshoreonly.com/forums/baja/242496-wt-best-prop-272-600hp.html)
knockld 11-18-2010 09:18 PM
Originally Posted by Baja_man (Post 3256209)
What kind of engine or other upgrades have you done to the 25 OL?
502 strocked to 509 new pistons, rods, heads, cam, etc, etc. Retuned, estimated hp ~600. Running dry headers (water reversion is what killed the stockish 502). Drive is stock with the exception of add-on external steering. I have a drive shower and I also swapped the water intake from the drive to the transom (lots of shallow silty areas in FL which were a pain with the low water pick-up). The drive pick up now just pressure feeds a hose and I installed a dump right over the top of the drive, works like a champ. No other changes to the hull but I have always seen ~1-2 mph faster than others claimed. I could always just walk away from my buddy with a 25OL 496HO even when he was alone and I had a boat full. The most challenging thing with the engine upgrades dealt with the valve covers. The new heads had higher lift rockers and I had to install the taller valve covers. This lead to PITA issues with stock merc mounting locations. All things considered it runs great, the only issue I have is slight loading up if I am at dead idle for along time. Everything clears it throat after getting back on the gas and I change the plugs farily frequently.
Baja_man 11-19-2010 07:24 AM
NICE!! Its good to see other 25OL out there beefed up. If your on the limiter now you could definately turn a 28 or maybe even a labbed 30. As you test more props start another thread documenting your before and after results.
