1" or 2" imco on 25ol
I was wondering if anyone is running a imco shortie on a 25ol with out ext boxes? Did it improve handling and speed or did it hurt it?
My boat is a 98 25ol with hp500, it has the notched transom. I will be changing cam and heads so motor will be close to 600hp. thanks |
Originally Posted by floyd7811
(Post 3282476)
My boat is a 98 25ol with hp500, it has the notched transom. I will be changing cam and heads so motor will be close to 600hp. thanks I am running Stelling box and shorty...still gettting it dialed in.... |
look up wild card he pick up 4 or 5 mph with a 3'' raised box by imco back in 07 and in 08 he add a 2'' shortie but spaced down one 1'' in the end and went from a merc 525 at 81 to 87 or 89 with the 600 merc. I pick up a lot with just a 2'' shortie on my 24ol power was 670hp 83.2 before carb change it was 650hp went 76 and no shortie.
what is your x dimenson
Yea, you need to know how deep your drive is in the water before anyone can give advice. Measure your propshaft centerline and report back.
thanks. i will have to wait till i get boat out of storage
Originally Posted by jeffswav
(Post 3299738)
Originally Posted by AIR TIME
(Post 3306418)
A 98 250OL SHOULD BE 7 1/2'', but I could be wrong:p, art
Regardless, order a -2" and try it then spacer it down if it's not right, although it will be fine with -2".
(Post 3306418)
| All times are GMT -5. The time now is 09:50 PM. |
