Corsa diverters for 2002 O/L?? where can i find some?
My boats in storage right now do i have to have a certain model number i need to look for ?? mine seem like the dont run straight parrell out the transom i think the come out of the riser straight but then drop a inch or two then come out the back my buddy has a 2004 baja outlaw and his go straight back we notice when we were looking the rear of our boats they looked a little different his are closer to his swim platform than mine ? did they change something from 2002 up?
mine says Corsa Quick Quite 2 on them i think
call corsa direct they are in berea ohio i got new ones direct a couple of years ago good people to deal with
www.bajaboatowners.com
1 Post
You know you have to pull your motors to put them in right?
I remember you and I running into this when we sold ours. Mine were straight and yours had the drop. I know you had HO's, but did you change yours when you replaced your mags? If you didn't have to it may depend on the model of the boat and when it was built.
I agree, but our boats are the same year and have the same bottoms. We both have the same setup as far as xboxes and shorties. I believe that we also have the same prop shaft height. Since yours had the drop and mine didn't is it possible that your engine is mounted higher or your exhaust comes out lower at the transom?
Corsa for sale...
