Originally Posted by Keith Atlanta
(Post 3360556)
+1 Raising them 3 inches creates a lot of issues you might not have thought about yet... Such as issues with the inner transom plate and exhaust and its all a pain in the a$$.
Originally Posted by Irishtornado
(Post 3360611)
[quote+TW720HVY;3360472]That is a good idea, but hopefully someone will post the answer saying the angle is 11.583º or something like that. :drink: :drink:
Be careful as having it too deep isn't good neither is having it too high.[/QUOTE] I am going to go with the neutral, seems to be the most straight forward approach. Hopefully. :party-smiley-004: |
All the parts that I got from Baja that had to do with the transoms were either marked 12 and 13 degrees. I believe the Outlaw series were 13 degree transoms.
brain41... thanks for the reply and information.
14 degrees.
Originally Posted by WOTW2E
(Post 3361424)
14 degrees.
02' & newer 20ol's......14 23ol...........................14 25ol...........................13 26ol...........................14 29ol...........................13 30ol...........................14 33ol...........................13 35ol...........................14 36ol...........................15 40ol...........................15 XT |
Sounds like your going to be neutral Rick. You won't gain from the box, but you'll gain 2" with shortie.
XT, thank you for the great information.
Dave... that is what I am more than likely going to go with. Some have suggested the 3" but then they will not work with the Bravo. |
Originally Posted by TW720HVY
(Post 3361627)
Dave... that is what I am more than likely going to go with. Some have suggested the 3" but then they will not work with the Bravo. You won't be sorry you did it. The ride and handling is night and day. Just make sure you use PLENTY of 5200 so you don't have any leaks. I'm not sure if your doing it yourself or having someone do it. |
Originally Posted by XT-Innovator
(Post 3361502)
Adam has the correct answer on this one. No series had a consistent angle. Newer models like the 26 were normally 14 degrees.
(Post 3361659)
I have a place that will have secure "big truck" parking... in fact it the same place where the work will move than likely be done. :drink: |
| All times are GMT -5. The time now is 05:25 PM. |
