Our new Baja 232 in Germany
Hello Baja Fans,
we got our new Baja 232 from Florida in December. Now we made some videos with my ipod touch. http://www.youtube.com/watch?v=56ZCBO1tcjI http://www.youtube.com/watch?v=ZE280MNsoNs http://www.youtube.com/watch?v=azWkag2cWO4 Please rate them! Best regards Baja 232... Speed changes You! |
Originally Posted by Baja232...
(Post 3373593)
Hello Baja Fans,
we got our new Baja 232 from Florida in December. Now we made some videos with my ipod touch. http://www.youtube.com/watch?v=56ZCBO1tcjI http://www.youtube.com/watch?v=ZE280MNsoNs http://www.youtube.com/watch?v=azWkag2cWO4 Please rate them! Best regards Baja 232... Speed changes You! Nice boat. Congrats. What kind of drive and engine are you running? Don't trim your bravo up that far while under way. You will trash your u-joint. It looks cool, but kills your drive. Happy boating |
(Post 3373593)
Hello Baja Fans,
Originally Posted by A.O. Razor
(Post 3373775)
Welcome to OSO.
Nice boat. Congrats. What kind of drive and engine are you running? Don't trim your bravo up that far while under way. You will trash your u-joint. It looks cool, but kills your drive. Happy boating the boat is powered by a 7.4 MPI Mercruiser with a Bravo I outrive. Thanks for the Tip, that i don´t have to trim my bravo up. Good boating. |
You should have to trim it up, but not to the point of throwing a rooster tail like you do. You will definately ruin your ujoints and outdrive doing that.
Also sounds like you are running your exhaust through the prop. Does this boat have the exhaust diverters on it? Captains Call? |
Originally Posted by Irishtornado
(Post 3373834)
Also sounds like you are running your exhaust through the prop. Does this boat have the exhaust diverters on it? Captains Call? The exhaust is running through the prob. The exhaust tabs under the swim platform are dummies. Sorry, because my english is not so good. Happy boating. |
Engine
Hello,
If you want to see the engine and the exhaust dummies, click at my name in Youtube and look into my Cannel. There is a video called 'Baja 232' . In this video is our boat on the trailer and at the and of the video is the engine. Happy boating. |
(Post 3373855)
Hello,
The exhaust is running through the prob. The exhaust tabs under the swim platform are dummies. Sorry, because my english is not so good. Happy boating. As was said. Do trim your drive out when running, you need to. Is this your first boat of thie type? If so, here is a few tips. Do you know where neutral position of the drive is on your trim gauge? Neutral trim is when your drive is trimmed so that the propshaft sits @ zero degree angle to the bottom. The drive will sit perpendicular to the bottom. I've tried to illustrate it here. Low line being the prop shaft and the top being the bottom/keel of the boat. __----- When at WOT. Start at neutral trim. Then trim out in small increments untill you start to pick up speed. When it has stopped gaining speed, give it a tiny click or two more on the up switch. If no more speed is gained, you are at what is the "right" trim. This can change depending on how much fuel, passengers ect. you have on board. You will need to play around with it, and find the best trim settings for different speeds, loads and weather conditions. |
(Post 3373593)
Hello Baja Fans,
we got our new Baja 232 from Florida in December. Now we made some videos with my ipod touch. http://www.youtube.com/watch?v=56ZCBO1tcjI http://www.youtube.com/watch?v=ZE280MNsoNs http://www.youtube.com/watch?v=azWkag2cWO4 Please rate them! Best regards Baja 232... Speed changes You! Was dir die Amis hier erklären wollen, das deine Baja niemals mit solch einer fontaine(rooster tail) hinten fährt! Dein Boot ist absolut übertrimmt und du zerstörst deine Kreuzgelenke!!! Have fun with your new Boat! |
Hello,
thanks at all for that useful information. You helped me very much. Now I have to stop doing a rooster tail, because I won´t buy every month a new Bravo. Happy boating. |
(Post 3374761)
Hello,
thanks at all for that useful information. You helped me very much. Now I have to stop doing a rooster tail, because I won´t buy every month a new Bravo. Happy boating. Have fun with it:signs069::boat: Never hesitate to ask if you need advice. OSO is always open:drink: |
What ever happened to the guy w the 25 OL over in Germany?
Take the top down when doing high speed runs, that will slow you down.
Originally Posted by Quinlan
(Post 3375246)
(Post 3375394)
WILDCARD I haven't seen him on any of the boards in over a year.
That was one hell of a nice 25. I had the opportunity to have Stephen take me out on the her. |
New Photo
Hello Baja-Fans,
now we are having a few new photos of our two baja 232 boats... http://www.boote-forum.de/attachment...5&d=1308051383 http://www.boote-forum.de/attachment...1&d=1307957532 |
Still triming up too high, be carefull
Originally Posted by jeffswav
(Post 3431963)
(Post 3432206)
Thanks for your tip... But it was only for the photo shooting
FWIW. Jeffsway is right though. Even for a photoshoot, don't do it. It'll go KABOOM CRUNCH CRUNCH CRUNCH... and make alot of other nasty sounds before you know it = $$$!!! |
(Post 3432486)
Nice pics. How is the trimming coming along? Are you starting to get a hold of it?
FWIW. Jeffsway is right though. Even for a photoshoot, don't do it. It'll go KABOOM CRUNCH CRUNCH CRUNCH... and make alot of other nasty sounds before you know it = $$$!!! I do the trim down. It's only for a few seconds... Best regards |
That does not matter, that is only determined by your limit switch.
Baja 232 in a mirrow
On our last boat trip we took a new video of our boat in the mirror...
[YOUTUBE]http://www.youtube.com/watch?v=PJ-f3bqWjz0&feature=feedlik[/YOUTUBE] |
Cool video. Can't believe how calm the water is. Not even a ripple..
Video
Now we have a new Video from our two Baja 232's
Press " I like IT " on the video Baja 232 vs. Baja 232 | Trailer HD http://www.youtube.com/watch?nomobile=1&v=0dJorba5Gi4 The Video "Baja 232 vs. Baja 232 - The Revange in Croatia" will follow the next days.. |
Baja 232 vs. Baja 232 - Die Revange in Kroatien
Now the full video is uploaded on youtube!!! have fun!!! And Press "I LIKE IT" on the video
http://www.youtube.com/watch?v=z5fM7iwWXa4 |
Nice Video and Boat's! But please put the camera behind the windshield for the next it helps with wind noise.
NEW Video
NEW Baja 4 Ever Video NEW
[YOUTUBE]http://www.youtube.com/watch?v=D-1_ih2nxeo[/YOUTUBE] |
Here are again two videos
- once of our new blue led' under the hood - twice of our trip to Ratisbon http://www.youtube.com/watch?v=2TkIU...1&feature=plcp http://www.youtube.com/watch?v=kaRJM...feature=relmfu |
(Post 3698615)
- once of our new blue led' under the hood - twice of our trip to Ratisbon http://www.youtube.com/watch?v=2TkIU...1&feature=plcp http://www.youtubeth.com/watch?v=kaR...feature=relmfu Nice to see that performance boats are being run on your waterways. Do you trailer it or keep it in the water at your marina? |
Originally Posted by AZ Boater
(Post 3699137)
Great videos! The LEDs look great. I'm in Southern Germany this week on vacation. Seems like great boating weather. I hope you are getting out on the water to take advantage of it.
Nice to see that performance boats are being run on your waterways. Do you trailer it or keep it in the water at your marina? our boats are in our marinas on the River Donau in southern Germany. The weather is not so nice... it' so cold this weekend... But on every nice day we go boating! |
Here is the green-yellow Baja 232 with its new green bilge... sooo nice Watch it now!
https://www.youtube.com/watch?v=Iy5qvPfoXwk |
Here is our new video from our Holiday... Enjoy!
http://www.youtube.com/watch?v=Nt9MA...ature=youtu.be |
| All times are GMT -5. The time now is 06:02 AM. |
