-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Swim Platform height location (https://www.offshoreonly.com/forums/baja/251671-swim-platform-height-location.html)
CoffIslander 04-18-2011 11:10 AM
I am picking up a new tubular swim platform from Extreme Marine this week, and was hopeing someone could give me the measurement from the top of their platform to the rubrail. It is going on a 99 25' outlaw. Any help would be appreciated.
Chrsbaja 04-18-2011 12:13 PM
I have a 2001 OL25 and I will take a look at it tonight. If you notice the rubrail on the back has a little bit of a curve and i am guessing you need to get a measurement from the middle (where the toe rope hook is). Looking at it yesterday since I am putting my name there I think it about 6", but I will confirm tonight and let you know.
C
Chrsbaja 04-18-2011 05:46 PM
I measured the swim platform and from the middle of the boat (rope tow) down from the top of the rubrail it is 7 3/4". That is to the top of the swim platform. If you go to the starboard and the port side it is 6 3/4" down to the top of the swim platform. This is not to the mounting brackets, only to the top side of the platform. Hope this helps.
C
CoffIslander 04-18-2011 06:35 PM
Thanks chrsbaja - that is what I was looking for!
CoffIslander 05-03-2011 11:21 AM
Guys - I have the platform and drilled all the holes, but I need some suggestions for sealing these holes. Should I caulk each bolt before pushing it through the transom, caulk the back of the platform around the bolt holes, or caulk the hole before pushing the bolt through? I'm concerned about water seaping through these holes and rotting the wood in the transom. An o-ring between the platform and transom might work? Any suggestions are welcome.
Baja_342 05-03-2011 12:02 PM
I have used 5200 in the past to secure and seal loose cover screws. It holds really well, but is messy to work with. You can do both the screw and the hole, have a wet rag ready for any clean up.
