Beeping alarm help!! >
Old 06-12-2011 | 07:46 PM
Default Beeping alarm help!!
Ok so the boat is a 99 232 with a 454mpi, bravo 1.
As i went to get on plane today the alarm went off .. solid so i throttled down and looked at all the gauges and everything is fine. got on plan everything fine. It did it a few more times after that but only if im taking a sharp turn or if the boat comes out of the water. Temp, oil pressure all good. I checked engine oil level thinking it might trigger it at times and thats fine as well.
Can it be the drive oil?
I also heard a sqreeching noise from the drive once or twice..
thanks in advance
FANTAZ28 is offline
Old 06-12-2011 | 08:58 PM
Ted G's Avatar
Yes, it is most likely low drive oil.
www.cbpba.com
Ted G is offline
Old 06-12-2011 | 11:04 PM
obnoxus's Avatar
Charter Member #1171
+1
If the bottle is full,,,,try unplugging the wire on the resevoir
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-13-2011 | 06:37 AM
t500hps's Avatar
21 and 42 footers
Originally Posted by obnoxus
+1
Or.....if it looks full, take it off and clean it out anyway. More than one person lately has complained about a full looking bottle that is actually full of sludge in the bottom (me included). I had a drive loose all fluid but the bottle still looked 1/2 full and the alarms did not go off.
t500hps is offline
