BOB M was decent but my stuff took a long time to get to me, every time we talked he said you need this now, you need that, well y didnt you tell me in first damn place..
Ya he forget to tell me about the change in firing order too lol i had to ? him about it and ohh yeah that it takes 3 metric screws not the standard ones... Sure the Comp cam was there quick good luck |
Originally Posted by stlliberator
(Post 3437795)
My 502 doesn't burn any oil. However it likes to leak it out of the oil cooler. And I can't get the fittings any tighter....oh well
Originally Posted by pantera232
(Post 3449952)
Originally Posted by arandaz
(Post 3450907)
Ya Bob might be getting a little too busy and is forgetting some things here and there. I had the same issue with my firing order and it cost me a starter and a weekend boating.
your old set up was a hyd cam flat tappet lifters, now you have a hyd roller cam thats worth around 30 to 40 hp. on the dyno you should be at 575 to 600hp with the new set up. you might want to send the carb to nickerson in penn. they can rebuild better than new = more hp. if you bought a used imco 2'' shortie that will make the boat handle better with more top end. my 24 hit mid 80s before some parts were stolen. I had 650hp2''shortie nickerson carb 1050. your new rpm range should be 5200 to 5400 with that cam.speed 75 to 76, with a shortie =77 to 80.my new motor is a gellner 572 blown 1100sc, there in ohio Dean is one of the best in the country so if your not tied to a builder call him 1st. for props the b1 26 works well with high x or shorties ,stock high then the mirage 27 or the rev 4 25 brett at bblades has a program where you can test his props once you now what works best keep it or have him lab it. good luck art
oh weight is 4000lbs for the ol or 240 sport same as ol but no fairing a windshield. the 25ol I think are 4600 and the 26ol was 5200lbs I could be off on the 26.
Originally Posted by spark plug
(Post 3437668)
i ordered my cam kit the other day. this is what i got http://www.cpperformance.com/p-11622...ifter-kit.aspx
its one step from my stock cam, and its a roller. Not going too crazy with. just a simple cam swap. |
Was it red and black graphics?
Originally Posted by BIGSLOW
(Post 3432022)
My buddy before he was killed had a 1992 24 OL with a 635 HP 540 c.i. Saw low 80's in that multiple times.
I owned a 1996 baja 240 sport with the 454 magum, i believe it was about 385 hp stock and ran 66-67 mph, it porposed so bad it was dangerous. We installed a b&m 174 blower with 5lbs boost 26 pitch bravo 1 prop, when finished it ran 81 to 82 mph straight and flat, no more porposing. Turned out to be the best boat i have ever owned
