I am running a 24 + 4 labbed prop and stock 502 Mag . I bump 5200 rpm and run mid to low 60's
Originally Posted by mikeoutlaw24
(Post 3434187)
450 hp
Originally Posted by baja_brian
(Post 3434223)
have a 25' with a 502... running a 23p m+ labbed by bblades it was dead on call them and let them do it. also have a 22p bravo 1 4 blade with some cup added and and hate the prop!
(Post 3434006)
what speed should i get out of this boat with the 502
Expect to see 65-67MPH GPS |
Originally Posted by caseyh
(Post 3434622)
Originally Posted by mpally
(Post 3435244)
If his 502 is making 450 hp, he will probably need a bigger wheel than a 23.
25" |
Casey! Why do you hate the b1???
I have a 22 b1 repitched to 23 with cup and runs well, could use some more cup to get bow higher but gets boat up well??? Was worried that the lab bed 23 wouldn't help whole shot cause I don't like to "have" to use tabs to get up with load?? |
Try a rev 4 23p...its a smaller diam prop than the bravo..thats what im running on mine with the same hp...awsome prop
We preferred a 22 Bravo over the 23 Mirage on our 25. The 23 would break loose in rough water and would bit again until we came off plane.
| All times are GMT -5. The time now is 01:16 PM. |
