Baja 342 Questions.
HOW the **** did you go from 40-250? thats more than 5 times.....
i mean, at most i see its being duble. if 50 bucks works for you now, 100 should make 2 motors working less hard do the same.
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I can watch the gauge go down.
Also you guys with 342s do you use tabs all the time to get on plane? or does it jump up pretty easy? (my 252 never nees tabs)
whats you cruse settings? tabs/ drives? or WOT settings?
At 50mph I set flat tabs and a couple ticks of trim.
Its just a big boat.
so nothing on tabs (all the way up is flat) and just bumping the drive up a few clicks? at what point does it start to blow out the props? 7ish? or higher??
man now you guys have me scared. haha no matter it cant be worse then my parents full oaded 330 SS with the same motors and bravo 3s....
