Silent Choice/Captains Call >
Old 07-12-2011 | 08:41 AM
TW720HYY
As you know. The two happiest days in a boat owners life, is the day he buys the boat and the day he sells it. Sorry couldn't resist
Seriously. Hope everything works out for you.
And back to topic. I like the Corsa CC too.
A.O. Razor is offline
Old 07-12-2011 | 04:49 PM
Oh believe me this statement is the truth with one right now.
TW720HVY is offline
Old 07-13-2011 | 04:55 PM
Thanks for all the feed back. I plan on keeping the motor stock or as close to stock as possible. It's not a fast boat and I am just going to have to realize that, on a good day "down hill" I may get 55-56 mph. But she still floats and allows for adult beverage consumptions and sunburns, beats the office!! Anyhow, I checked with Corsa and talked to one of the sales guys there, he informed me that a system would cost around the 2000# range. Seemed kind of pricey for nothing more than noise.
I was told that i needed a 2 inch drop down style corse captain call exhaust (more $ than normal) as my boat has a 3" spacer above the riser. I checked it out and I dont see the so called spacer. Anyone know what this would look like?
Looks like i may just have to bite the bullet and go with the captains call.
Thanks for the input!
bflobaja is offline
Old 07-13-2011 | 10:47 PM
I think you misunderstood, or he explained it wrong. What you might have is a riser that is 3" taller than the "normal" ones. Can you post a pic? Anyone ever heard of a spacer to put under the exhaust risers?
Old 07-19-2011 | 12:10 PM
My 2-coppers worth, I installed silent choice on my 27PC after replacing the 7.4 with a 502 MPI. Cutting through the 4-inch transom with a 4-inch whole saw was the hardest, had to cut from both directions. Installed Corsa muffler tips along with flappers to keep the possibility of water intrusion when stopping. They have worked very well up to this year. They are spring loaded open and need power to close. One closes and one is intermittent. Looks like I have some corrosion on the contacts which are hard to get at. Thinking of replacing the connectors with some water proof ones with hopes this will fix it.
AllDodge is offline
Old 07-19-2011 | 07:17 PM
These are off a Baja...
Attached Thumbnails Silent Choice/Captains Call-dscn3076.jpg
TW720HVY is offline
Old 07-20-2011 | 04:51 AM
I dont know if it will work on your set up but i have a set of gil manifolds, risers and the captain call diverters with wiring harness that i took off my hp500 that was in a 25 outlaw
floyd7811 is offline
Old 08-04-2011 | 08:17 PM
Thanks again for feed back. that must be the 2 inch drops that Corsa was talking about.
bflobaja is offline
