little bubbles/ blister on hull
we had it happen, twice, first time they fixed them, the whole sanding them down, then letting them dry, and patching them. But then they never matched the gel colour well. After the first repair did not stick, the boat ended up going back to the manufacturer and ended up getting a whole new hull.
beginning of Osmosis. From boat sitting in the water. Water penetrates the Gelcoat then swells with the fiberglass and can't get back out of the gelcoat. Proper way to get rid of it is to have whole bottem of boat sanblasted in the fall and leave it open for the winter and in the spring, have it sealed and re-sprayed. Or blast and bottem paint(will hurt resale)
i think i will be doing that in a few years, not this year, how long do you have to wait for drying time
Mine was a 97 Hammer. Water line down had them. I went through the whole process above, but I bought the boat knowing this needed to be done and discounted the price to have it repaired. To be quite honest, if you trailer the boat all the time and plan on keeping for a long time then I would bother fixing, but if you plan to re-sell the boat in the next year or 2 then it will need to be done.
from what you are saying , i better get it fixed soon. to bad it isn't under warranty, but if those years had a bad run, then they should still, fix it and made it a recall. but since the company is bought by fountain, i am **** out of luck. and baja would probably have laughed at me also if i brought it up now
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Can't see how the bunk slides would work. If you dunk the trailer and retrieve the boat, they're wet, obviously. And with 5000 lbs of boat sitting on them, they're not going to dry out between the slide surface and the hull surface. How is that different than carpet, except for slightly less water?
Unless I'm missing something.
