Marine Survey >
Marine Survey
Marine Survey
Old 10-18-2011 | 04:49 PM
Originally Posted by kragar
anyone in or near New Jersey? Found a 29 with 500s that seems to be in decent shape. Also looking for a surveyor in the area too. Want one that will do compression tests and of course check the stringers for damage with having these motors.. Any help is appreciated.
If the boat doesn't have hydraulic steering and offshore mounts the motors where put in the boat most likely was a 7.4L boat. with correct engine mounts motors shouldn't matter. Make sure you have motors checked for saltwater damage. I've seen the water passages in the intake and thermostat housing ate through from salt.
Irishtornado is offline
Old 10-18-2011 | 05:22 PM
Thanks Irish. It has full Hydraulic steering. Was a factory boat. He just moved to the area and this is first year of salt and flushed regularly. I have a line on a surveyor who will check things out once I am ready to move on it. On another note my buddy just picked up a 98 302 for $30k with full hydraulic steering as well with 454mags in it. Nice boat and great room in it.
kragar is offline
