Boss 302 Weight
What is the dry weight of a Boss 302 w/twin small blocks? I have a buddy of mine that is putting it on a 5500lb shore station lift and is holding up fine. I am considering doing the same with mine, but I am 6500lb dry weight. thanx in advance for your response,
tom |
Originally Posted by FISHIN SUCKS
(Post 3537623)
tom |
Originally Posted by A.O. Razor
(Post 3537643)
Putting a 7200+lbs boat on a 5500lbs. lift is not the best of ideas and the insurance won't like it either. If something happens to the boat or persons around it, you're screwed. Same goes for a 6500 lift. You also need to consider what happens if a storm comes. Then the lift is under even more strain, and you don't have that safety margin you'll need. Get a lift with the correct rating.
Just upgrade the cables - $185. It will increase the capacity enough to feel comfortable.
Originally Posted by Keith Atlanta
(Post 3537757)
| All times are GMT -5. The time now is 08:33 AM. |
