Myco Trailer with Drive Guards - Should I keep
Best trailer I ever had was a Myco.
I would just modify the guard for garage usage, and engineer it so that it can be pinned/bolted on once you're out of the garage, if you want to retain it at all. A few touch ups and you're ready to go.
I wouldn't sell a trailer for this reason alone, when a bit of ingenuity will get you what you want/need! Post some pics up and we'll give some ideas.
Can you make a little 'bump out', 'dog house', or enclosed lean-to off the back of the garage to give you the clearance you need?
Also, look at the other end of the trailer. Is there anything you can do to shorten the tongue of the trailer? Going from surge brakes to EoH brakes, just removing the actuator can sometimes save a foot of trailer length. How is your tongue weight? Do you have room to slide forward a bit and shorten the drive guard?
What does the back of your garage look like?
Also, look at the other end of the trailer. Is there anything you can do to shorten the tongue of the trailer? Going from surge brakes to EoH brakes, just removing the actuator can sometimes save a foot of travel length. How is your tongue weight? Do you have room to slide forward a bit and shorten the drive guard?
The garage isn't built yet. It's in the planning stage. I'm limited to 36 x 48 garage. From stem to stern (trailer) is around 45 feet. The actually interior garage length will be about 47. It's close. I think it will work as is, but it's going to be tight. I'm really not a fan of the drive guards. I would never get one, it just came with it. PITA.
Next thing I'll be looking for is a boat trailer dolly. Going to start a thread looking for the best option for the money.
Thanks for the input!
