Power Trim Issue >
Power Trim Issue
Power Trim Issue
Old 04-10-2012 | 10:20 AM
Default Power Trim Issue
Hello. On the trailer, my drives were all the way down. To trailer it, I raised the drives all the way up. When I fired her up, only the Starboard drive would lower. The Port drive will not lower and I don't hear the trim pump at all when I push the panel buttons. It is still all the way up. Relay issue? THANKS for any thoughts!
imartin is offline
Old 04-10-2012 | 11:17 AM
obnoxus's Avatar
Charter Member #1171
yup,,,,,relay,,,,,or could be switch,,,,, but realys are common,,,,,smack it !!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-10-2012 | 02:29 PM
Will give that a try! I believe green wire is the down relay, will jiggle that and see.
Thanks!
imartin is offline
Old 04-11-2012 | 07:06 PM
Jump the solenoid and see if she moves.
If it does, you can take them apart and clean the contacts.
puzzleboy is offline
