-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Cabin lights 342 (https://www.offshoreonly.com/forums/baja/275044-cabin-lights-342-a.html)
mittens 04-23-2012 10:42 AM
Cabin lights 342
Ok so the cabin light switch in the main panel in the cabin, turns on all the flush mount over head lights.
Anyone know how to change those bulbs? and if so ever put a LED in there?
also baja wired the light in the head to this switch, so you can have just the bathroom light on. going to change that, but wondered if anyone knows where that light in the head connects? at the switch panel? or is it in parallel with the other over head lights?
would like LED in the 4 wall amps as well but the ovver heads are used more.
Baja_342 04-23-2012 12:39 PM
2 Attachment(s)
Just twist the ring to get to the bulbs in the overheads. I replaced the corner ones (helm switch) with red LEDs, as those are the ones I use more.
mittens 04-23-2012 12:41 PM
Yea I know about your thread, but my new boat has different corner lamps then those, and I want to change the bulbs out in the flat ones that are over head...
jeantyou 04-24-2012 01:36 AM
you said the cabin light switch in the main panel.
it is in parallel with the other over head lights.i think
:thankyouthankyou:
bathroom light
mittens 04-24-2012 07:00 AM
I dont think so. if i only turn on the cabin lights switch on the main panel in the cabin, the over head flush mounts work, and the bathroom light.
if I use the cabin light switch on the dash, it give the 4 wall lamps power. seams to be separated, but will try again to make sure.
thanks for the link!
mittens 04-26-2012 03:10 PM
so just ordered 10 of these.
6 for over head and 4 for lamps, think they will fit?
http://www.sencart.com/g4-25-smd-led...k-12v_p20.html
Plowtownmissile 04-26-2012 03:23 PM
If you know where I can get a couple replacement lights (the whole light assembly) like you have pictured, I could use two new ones.
Baja_342 04-26-2012 05:58 PM
Yes. I have a link on my laptop. On my phone right now. Give me a day or so and I'll post it. I may have in the last year or two if you feel like searching.
mittens 04-27-2012 09:05 AM
http://www.rvparts.com/product-89-8050064R
Plowtownmissile 04-27-2012 09:53 AM
Thank you very much!
