Baja hulls: which models share them?
Custom Interiors & More
The 280 Force, 280 Sport, 280 ES, and 280 Sportfish were all built from the same hull molds. There were a few "Baja 300's" built in 1991 that were renamed 280 ES models and the 300 ES became the Baja 320. The 91' brochure did not show that model because the new Baja 290 was suppose to replace that model. There was also a breif period around 93' we introduced the "Renegade" based on the same 280 ES with a white lowered windscreen and wild paint.
XT
XT
the 322 also.....falling off the pad in a 320 isnt very fun.
XT
XT
Yep, The old 320 Force hull was actually used to make the 33 Outlaw hull plug, but we added a rounded delta keel, reversed the chines a couple degrees, added a foot to the nose for looks, and then made the hull sides smooth (convex, not concave). The 342 is a 33ol hull with the molded swim added. We also made the 340 Sportfish by shortening the running surface of the 33ol hull about a foot then adding about two feet of the molded OB tub area.
XT
XT
