-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Will a 24 Outlaw fit on a 272 Trailer? (https://www.offshoreonly.com/forums/baja/285160-will-24-outlaw-fit-272-trailer.html)
baditude 09-20-2012 10:02 AM
Will a 24 outlaw fit on a 272 trailer with out modification? From what I read there the same width and dead rise and overal hull length is close and the 24 has a extension box. got a good deal on the trailer was just wondering if i needed to mod the trailer before i put the boat on it.
Crossett 09-20-2012 10:28 AM
I couldn't tell ya, but i'd like to see pics of the boat.
baditude 09-20-2012 10:37 AM
It wont let me post pictures. whats the way basic members can post pictures?
Crossett 09-20-2012 10:57 AM
You can't host pictures on here unless you have a paid account. You need to use a third party host, like this.
http://tinypic.com/
puzzleboy 09-20-2012 11:03 AM
272 hull is basically a 25 foot running surface, with 2' of swim platform overhanging at the back.
I would think your trailer will work just fine, especially if the bunks are set at the same deadrise.
The only issue I could see is if the strakes are different between models, and those could end up on a bunk (I went through this) instead of interspaced..... XT would probably know right off if there are any differences.
Easiest thing - try it! And make sure you've got adequate tongue weight for decent towing. You might have to move the bunks/boat/axle as applicable to acheive this, but I think the boats or so similar that you shouldn't have an issue if it was set up properly before.
92nsx 09-20-2012 11:25 AM
Photobucket.com for pics
baditude 09-20-2012 11:47 AM
Ok here are some pics of the boat and the trailer.
http://s1266.beta.photobucket.com/us...ry/?view=media
Crossett 09-20-2012 11:50 AM
Nice, what kind of speed are you seeing?
baditude 09-20-2012 11:53 AM
88.7 with the maximus going to be testing another 5 blade soon
JasonSmith 09-20-2012 01:54 PM
How much power is the engine making? It is a stock 496 Mag HO (425hp) and the Whipple is making how much boost?
baditude 09-20-2012 01:57 PM
Its suposed to be at 705 hp 655 is what the whipple kit is supposed to produce and Dana claims the headers are good for 50. Its just got the 5 pound pully on the 2.3 liter whipple so prolly 3-5 pounds of boost.
Crossett 09-20-2012 03:23 PM
What was the reasoning behind using an extension box? What differences did you notice? Did you have to raise the engine/exhaust up?
baditude 09-20-2012 03:30 PM
I bought the boat built but the motor was raised 4 inches and the exaust had to be recut the box is nutreal and it has a imco 2 inch shorty it rides like alot bigger boat with the extension box like it's a 25. But docking it is kind of a pain with the prop further away from the hull
Crossett 09-20-2012 03:34 PM
I wasn't aware that extension boxes changed low speed handling characteristics. That's interesting
baditude 09-20-2012 03:37 PM
It's just at idling in reverse it's different other than that it's the best handling boat I've had
baditude 10-02-2012 11:40 AM
The trailer fits great the way its set up now the bunks go back 6 inches futher than the transom, might have to adjust the mast or just make sure the tabs are always up. here are some pictures.
http://s1266.beta.photobucket.com/us...ibrary/trailer
XT-Innovator 10-05-2012 07:12 PM
Sorry, I missed this one. The 24ol is the same hull both the 25ol and 272 are based from so the trailer should be a good fit. I would adjust the winch stand back to the point where the rear bunk support bracket is right under the transom wood for the best support. Tongue weight might be a little more than you need right now?
XT
baditude 10-06-2012 07:03 PM
It pulls great now I only trailer it 10 miles a year to storage in the winter and back to the water in the spring I may play with it next year thanks for the info!
