-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   fuel pressure (https://www.offshoreonly.com/forums/baja/292983-fuel-pressure.html)
conneroutlaw 03-14-2013 04:49 AM
fuel pressure
what type of fuel pressure do i need at idel speeed in neutral
for a 502 w a m1procharger
or just in gear what pressure do i need, i am runnin about
6 1/2 at idel speed , or just in geast,
bajaboy217 03-14-2013 04:32 PM
Is this a 502 procharged carb or fuel injected setup?
Ebay Ed 03-14-2013 04:39 PM
i am guessing carbed since he only has 6 1/2 at idle injected wont even start with that low of pressure
bajaboy217 03-14-2013 05:18 PM
Good point, I had a m1 on one of my old fuel injected motors, psi was running about 40. For that setup pro charger recommended 37 to 42 psi and i had to run a larger fuel pump and i installed a wide band afr gauge so I could see if it was running rich or lean. I'm not sure about the carb version. Conner Did you talk to pro charger to see what they recommend? I would also say that you should find out what the pressure should be under boost at wot. If it runs lean under boost then your in trouble .
conneroutlaw 03-14-2013 09:09 PM
carburated 502
conneroutlaw 03-14-2013 09:10 PM
you are correct carbed
conneroutlaw 03-14-2013 09:12 PM
the fuel pressure jumps up when i hit the throttle
it is nice to get good info here,, and not argue who has the best boat , but to help each other arn't we all in the same rat race
Hot Tub 03-15-2013 11:57 AM
I think I'm running about 8 to 10 PSI at idle on mine. The fuel pressure regulator needs to be boost refrenced to increase fuel pressure as boost increases. I believe it's a 1 to 1 ratio; so, if you start at 10 PSI and 0 boost, at 5 PSI boost, you would have 15 PSI fuel pressure. This is due in part to that with Procharger-carbed systems, the carb is enclosed in a box and the fuel pressure must increased to overcome the boosted pressure in the box.
conneroutlaw 03-16-2013 04:54 AM
i will thanks
conneroutlaw 03-16-2013 04:56 AM
i will relay the message to my mechanic
thanks folr the info
bajabob 03-16-2013 08:50 AM
you have a carb you need bigger fuel lines and good high volume pump.. 8 pounds of pressure is all you what . thats at a idle to wide open . put a af box on it and you want to change the jets on the carb. do the pri. first then the sec. at wot.
