-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Prop is stuck (https://www.offshoreonly.com/forums/baja/296885-prop-stuck.html)
pagerboy 05-23-2013 11:00 AM
Prop is stuck
Prop is stuck on shaft won't come off any ideas? Tring to change drive oil
pagerboy 05-23-2013 11:08 AM
Bravo one?
nailit 05-23-2013 11:23 AM
what have you tried?? spray lube (liquid wrench or?) and beat with a rubber mallet?
pagerboy 05-23-2013 11:29 AM
Been doing both right now
Nightlife1970 05-23-2013 03:51 PM
Did you take the prop nut off?
nailit 05-23-2013 08:43 PM
Get a big ratchet strap.. tie to the prop and try to put an even bind... to tree / truck??
Put nut on where nut has full treads on shaft.. just shy of flush with shaft..
Tap on nut with hammer..
If you have help.. could have him try pulling as you hit nut first??
fleg1 05-23-2013 09:43 PM
I don't mean to laugh but that was freaking funny as hell!
Nightlife1970 05-24-2013 12:00 AM
Glad someone gets my humor
Randy Nielsen 05-24-2013 01:54 AM
Take a three jaw puller & install it on the hub, screw down the center bolt down to put pressure on the prop shaft. You can spray some lube on the shaft but leave pressure on it. Come back after a half hour or so & smack the tightening bolt right on the head a good wallop, the prop should pop right off. Randy
nailit 05-24-2013 08:46 AM
iIt was pretty funny!!! I was trying not to rub it in to the op.. :daz:
