454 Mercruiser Cam and intake exhaust? >
Old 07-08-2013 | 12:22 PM
Default 454 Mercruiser Cam and intake exhaust?
I have a 454 carbed 330 In my baja and the engine is toast. So im picking up a good used 454 and a set of 781 heads. So my question is what cam and intake would be a good choice? I am also looking in to some exhaust upgrades what is recommended?
Liftedsilvy is offline
Old 07-08-2013 | 07:53 PM
Full Force's Avatar
Merc 420 cam, dual plane intake.... any aftermarket exhaust or stock take off 496 exhaust for a budget..
Full Force is offline
Old 07-09-2013 | 12:26 PM
Where can I get a Merc 420 Cam? Do you know the specs on the cam? I was looking at these manifolds what else would have to be changed to run these? and are these the right 496 manifolds you mentioned?
http://www.ebay.com/itm/Mercury-496-...a12e6c&vxp=mtr
Old 07-09-2013 | 01:06 PM
Full Force's Avatar
http://www.google.com/url?sa=t&rct=j...48705608,d.aWc
Old 07-09-2013 | 01:07 PM
Full Force's Avatar
Yes that's right exhaust too, budget exhaust.... bolt on and go!
Old 07-09-2013 | 03:03 PM
Nightlife1970's Avatar
So they bolt on any 454 as in old 1988 versions? What gasket do you need?
Nightlife1970 is offline
Old 07-09-2013 | 03:10 PM
Fuil force...question, If I threw on rec. port heads, and that cam and had the ecu flashed or replaced it with a mag ecu, would I have a nice 400 hp motor or a time bomb??
phragle is offline
Old 07-09-2013 | 03:29 PM
Full Force's Avatar
Yep, that's what I did when I built my 320 BAja.... regular BBC header gaskets
Old 07-09-2013 | 03:30 PM
Full Force's Avatar
Should I would think.... just make sure approaching 400 HP you have Inconel valves..
