Rear facing speakers..... suggestions?
Will do. Yep, easy wiring run over to the amp under the rear bench.
I already use the grab handle above the boarding ladder for my marine BBQ mount.... lol
Hook'em, that may be a great idea! Instead of using the grab handles on the bolsters what about using the grab handle above the boarding ladder? A simple clamp on rail mount could be used similar to these (but sized correctly). No holes (but visible wires).
http://www.ebay.com/itm/PIAA-30710-A...b30337&vxp=mtr
Puzzleboy, your may be onto something there as the wires would just drop down between the coaming and the hatch. Post a picture of your prototype or mock up if you work on it tonight.
Dan
Dan
http://www.markertek.com/Connectors-...nc/NL2FC.xhtml
Made one bracket tonight out of .050 or .063 stainless steel I had laying around. Check out the pics, see what you think. It picks up on 3 of the hatch hinge bolts (which are extra long anyway), so it's very simple. The speakers go up and down with the hatch as necessary, with no clearance issues.
I think if I shorten and polish the bracket to a mirror finish, it won't look too bad at all.... thoughts? I like it because it doesn't intrude into the sunpad area, the speaker wire can easily go down under the hatch area, and I can install the speakers and brackets in about 5 minutes. And most importantly, the speakers can't fall into the water...
