-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   fuel guage adjustment (https://www.offshoreonly.com/forums/baja/302721-fuel-guage-adjustment.html)
dazrum 09-09-2013 12:10 PM
I have a 2001 Baja 232. Is there any an adjustment to the fuel guage which is made by Gaffrig precision enginering?
Strip Poker 388 09-09-2013 12:23 PM
id like to know too
dazrum 09-09-2013 12:28 PM
Mine was reading around half full and I took 60 gals I think the tank holds 89
jetskidrewski 09-09-2013 07:46 PM
232 holds 74 gallons
Bajadreamin 09-09-2013 09:32 PM
Mine does the same, 30 gallons left to go after it hits the full mark, there is an adjusting screw on the sender I guess, Gonna try it this fall when i winterize
dazrum 09-16-2013 09:50 AM
I got to look at the sender yesterday. No adjustment on the outside. I redid all the connections to see if it helps. Tank is full now so I can not pull the sender mechanism to check it for movement etc. I will do that when I am low on gas.
nailit 09-16-2013 10:55 AM
Is there an float arm?? usually they have a float that goes up and down.. like a toilet float.
Possibly bend it?? if show full too soon, then bending it up would work... trial and error method though...
I usually kept my 25ol full and knew how much it would take to fill at 1/4, 1/2.. 3/4 was always crap shoot as it really started to move to 1/2 quickly after I burned close to 1/2 half tank. 33ol has been a challenge.. don't want to carry around 186 gallons of fuel when that would last us 4-5 trips.
dazrum 09-16-2013 01:39 PM
Float arm would be inside tank and length of arm should be 1 inch shorter than the depth of your tank if it is aluminum and 1.5 to 2 inches if it is plastic.
With tank near empty I would remove sender completely and check it for proper length and movement. If that does not take care of the problem I may replace sending unit.
dazrum 09-16-2013 01:44 PM
One other thought would be to add a resistor to the sender output line . I would have to check with the more electrically intuned boaters to see if that might work
