322 vs 30 outlaw hull
Are the hulls the same on these ?? I assume the outlaw has a faster design but I'm not sure?? I really want a 33-36 outlaw but I saw a nice 322....Opinions??
The 322, 30 and 33 all have the same hull design to the best of my knowledge, the difference is the gunwhale and transom characteristics. The 322 has higher gunwhales which inherently make it a taller and better boat for rougher sea's (aka offshore) while the 30 and 33 Outlaws are shorter in stature and designed more for all out speed rather than surf. The 322 also incorporates a built in transom platform/step while the Outlaws have add on's. I have ridden in and worked on all three models and by far IMO the 322 is the more stable and predictable boat, but not the fastest. I enjoy mine.
Disclaimer: [These are just things i've noticed over the years, so the accuracy is not gauranteed.] |
Isn't just the Deck taller on the 322? XT would know for sure..
Trip, how is it more stable and predictable?? I may agree with you with 3 blades or spinning IN on the 33ol b/c my blew out and would fall over in "sharper" turns in a small canal, but 4 blades spinning out fixed all that and its very stable. Spinning IN felt unstable but didn't blow out. |
All three are different hulls, but they do share the same deadrise and 1 & 1/2 set of strakes per side. They all have a delta pad keel, but the 33 is more rounded, and the 322 is much shorter and flat like the 30ol. Chine width is the most narrow on the 322 and level. The 33, and 30ol are wider with a 2 and 5 degree down angle. The 322 has very tall hull sides mostly at the rear, but a shorter overall running surface than the other hulls. Owners of all three models will most likely claim to have the better design.
XT |
What does the chine angle help & hurt?
handling....
Originally Posted by nailit
(Post 4045125)
Trip, how is it more stable and predictable?? I may agree with you with 3 blades or spinning IN on the 33ol b/c my blew out and would fall over in "sharper" turns in a small canal, but 4 blades spinning out fixed all that and its very stable. Spinning IN felt unstable but didn't blow out. Also nailit.........What boating events are there to do in LA this time of the year? Any? Any thing ever happen on Ponchartrain? |
Never actually had chance to get mine in rough. Had her in 2-3s coming back from a horn island run in gulf, but wife and friends sat in back so i just took it easy and plowed though that was pretty smooth.
Not too much going on right now, weather is hot one day and cold the next. And by cold, I mean 40s :-) We have a club that lists all event though.. www.gcoffshore.com Take care |
Originally Posted by Keith Atlanta
(Post 4045136)
Originally Posted by kennyo
(Post 4044940)
A friend of mine had one ( a 320)a few years ago, it's a 30' boat, nice cabin ( with a high center of gravity that goes along with it) Mcleod bolsters were standard, engine access wasn't good. It had a large pad and with inside rotation, had a tendency to fall off the pad, which at 70+ wasn't a fun feeling....outside rotation, it behaved fine. They did reduce the pad size on the 322 ( and changed the styling of the engine compartment vents) When they were building both, I preferred the 320 over the 32magnum/caliber/outlaw, up unit I drove both models. |
Thx for the link...
