-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Factory Fresh Water Flush Question? (https://www.offshoreonly.com/forums/baja/30848-factory-fresh-water-flush-question.html)
CigDaze 08-18-2002 10:38 AM
I've got the combination unit...Both Low-water pickups and the side pickups...Is this what you guys have?
Dock Holiday 08-18-2002 08:23 PM
Yeah Daze,
The new XZ drives on my boat are boat low and side water pickup. I understand from the dealer the the side holes do most of the work, and the low is to help clear out trash, sand, etc.
I put the orange plastic boot with the hole plugged on the lower and the ears on the side with the hose to it. Works great to flush both the drives and engines.
Mark
cuda 08-18-2002 10:43 PM
I'm not sure if this applies, but on my Formula, there is a valve under the gunnel that directs the water to one, both, or no engine. I found this valve the hard way, burned up a seawater impeller.:rolleyes: Remember, this is a twin application.
skygod 08-20-2002 07:36 PM
I have 2 connections in the engine compartment, one for each motor.
Mark in So. MD 08-20-2002 10:26 PM
skygod, do you have to turn valves to use those, my friend has a 96 32Fountain and he has them in the engine compartment w/ valves. Damm thing is, one time he turned one back but somehow forgot to turn the other back, well, that toasted the water pump.
skygod 08-21-2002 03:49 AM
Mark,
No valves, just screw it in and fire it up.
Dock Holiday 08-21-2002 08:06 AM
Thanks Skygod,
Mine is like your's, no valves.
Mark
skygod 08-21-2002 02:19 PM
It's great we all have this forum to share our experiences. I think of all the things I did not have to learn the hard way since this board started, and the money this board has saved me.
