Trailer trim on 33 Outlaw
One thing I noticed on the 33 is lack of trailer trim, which my 25 had. I've got the normal trim in throttle, plus 3 switches (P, S Both), which seem to do nothing.
I go to sandbars a lot and really can't get the drives up very high (just the normal full out operating position). The lakes getting lower this time of year:D Thanks ... |
hmmm....my '00 has it. :confused:
jawbreakerkid,
Mines a '99. Where's your's located? |
On my 36, I have a trailer switch just left of the two drive adjustment switches. You have to push all three at the same time. It brings it up a little higher than just the trim button by themselves.
I thought all boats had a trailer mode for the drives? Good luck Mark |
Not to sound like a smart A$$. Did you push all three at the same time. That how I do mine. Now I'm wondering if only the b button needs to be pressed. I'll try it on Sat.
my switch is located just to the left of the P&S trim switches. instead of pressing all three, i usually press the trailer trim switch and hit the trim switch on the throttle.
1 Attachment(s)
here is a pic....
Same set up as mine. No mention of trailer, only trim (the switches aren't labeled like yours). I've never tried all 3 at once, just the B. Nothing happens. I'll have to check to see how (if) they're wired. Sounds like there's a couple of different combinations to try.
Perhaps this is just me having never operated a twin screw boat...
But can you actually trim the port and starboard engines seperately? Even with a tiebar and hydraulic steering? |
dloftis- yes, you can do it. most pleasure boaters do not, but in racing, it is common in turns.
jbk |
| All times are GMT -5. The time now is 07:58 PM. |
