Heres something to check #1 , panel switch in cuddy, #2 fuse for the radio coming of battery switches, #3 fuse close to the back of radio hot wire, # 4 THIS WAS MY PROBLEM the push
button circuit panel under steering wheel went bad replaced whole panel and works just fine. great lakes skipper has the Baja original ones for your Baja. good luck.. |
Exactly what I needed, though I didn't know there was a circuit panel under the steering wheel. I'll check on that as soon as I get back to the boat. Thanks to everyone for the input.
If all else fails run both the red and yellow wires directly to a battery under the seat, make sure you fuse close to the battery. Use the power button on the radio to turn off. Quick off is stand by, hold down power button for 3 seconds to get total off. This fix should take you minutes
I have always ran my boat stereos directly to the battery, switches and breakers make it too complicated for something that is used more than anything on the boat. |
Agree... The 4 points of switches / fuses just seems to be a little bit of overkill for a stereo. I guess we'll see that change about the time we see Walmart open all 28 cash registers.
I see you launched in pcb where is a good place to launch a 38 ft power boat
There isn't a good place to launch a 38 foot power boat in Panama City Beach. We found two places that we were willing to try, and settled on St. Andrews Park. It definitely had it's challenges. Getting the boat/trailer into the park wasn't all that tough, but getting it backed into the water (on the ramp) was a real PITA. There isn't much room to turn around, and you probably wont be able to launch or recover at low tide, so schedule your boating around it. Relative to the jetty, the launch location was great. If you plan to store your boat there, I have some great info for you if you want it.
For further reading: I was the only one in my party that could legally operate the boat AND drive the truck (pulling a 40 foot trailer). The locals fussed when I left the truck on the ramp to park the boat, and they fussed when I left the boat tied to the dock to park the truck. Be prepared for indigenous crybabies that will overreact if they experience a 5 minute delay. |
| All times are GMT -5. The time now is 10:51 AM. |
