Propping a 272 >
Propping a 272
Propping a 272
Old 05-29-2014 | 11:13 AM
Ebay Ed's Avatar
i have a 500 efi in my 1998 272 spinning a 25 mirage + that has a mercury lab can only spin it 5100 and runs 70.9 it blows out just before it drops on to plane but if you ease in to it it is fine oh and my drive height is raised a couple of inches over stock i know mine has a little left in as the computer is good to 5600 but i am pretty happy with it for now until i get bored and whipple it LOL
www.bajaboatowners.com
Ebay Ed is offline
Old 05-30-2014 | 03:42 PM
Originally Posted by puzzleboy
Yeah, that's what's on there now. A Mirage 23 plus 3 blade. I'm fine with the performance, just wanted to make sure I was getting everything she had. 4750 RPM sound about right?
If you were buying a spare prop, would you get another identical?
4750 RPM sounds like you're down on power to me. You should be closer to 5000. The M+ 23 is the right prop for your boat HOWEVER it needs WORK. They have high slip numbers stock and blow out easy. With the diameter reduced, pitch increased, blades thinned and cup/rake adjusted for the Baja to carry the bow, you can pick up substantial "top end" without giving up anyhting else. My +/- 450HP with Bblades custom wheel (based on the M+23) runs very high 60's.
Hook'em is offline
Old 05-31-2014 | 06:31 AM
Well, she could probably use a tuneup too. Who knows how accurate the tach is also. What's one of those tuned props worth, roughly?
puzzleboy is offline
Old 05-31-2014 | 08:48 AM
DRP
Would a 21 plus be better for him rather than all the work on the 23? I'm sure if he is looking every last bit out of it the 23 would be better but I would think that a 21 plus could be thrown on and be done. On the other hand though, it might be a wash?
DRP is offline
Old 05-31-2014 | 08:51 AM
DRP
Not to hijack, but since we are on the subject...I am getting a 496HO for my 272 and on hand I have a 21 plus and a 24 bravo 1...I would like to use one if I could rather than buy another or lab. Would one be ok? I know the 21 is too small and the 24 is too big, but would the 24 be ok or will it be lugging the motor too much?
DRP is offline
Old 05-31-2014 | 12:43 PM
True. Don't forget The ICM in the distributer cap while you're at it. I can't quote prices of coarse but mine was done at the shop in WI, (there's an awesome recipe in my file) less than 500 to have it tuned, balanced and blue printed I believe, but you'd have to talk to him to be sure. A lot depends on what you're starting with too.
A 21 wouldn't yield any top end gain for sure. I understood "top end" was the stated goal.
Hook'em is offline
Old 05-31-2014 | 12:44 PM
The 24 is prolly perfect for a stock wheel. Bolt it up and nail it.
Hook'em is offline
