Cooler and tote question for Islander owners... >
Old 05-30-2014 | 12:06 PM
Default Cooler and tote question for Islander owners...
I am buying the 232 Islander that I posted about prior...I was looking in there and wondering where the best place for a cooler would be. Just wondering what you experienced people would have to say or have any advice.
Also, the engine compartment is huge. Has anyone mounted a tote in there to store stuff? If so I was just wondering how and if there would be any down side to that.
Thanks!
Abs777 is offline
Old 05-30-2014 | 12:14 PM
Mine came with an Igloo marine that fits nicely under the center of the rear bench, its a little bit of a pain to have to have someone move every time you want something out of it but as I am sure you have already noticed there is not much floor space in these things.
brod is offline
Old 05-30-2014 | 03:07 PM
Same here, middle of the back seat best spot for it.
bats05 is offline
Old 06-01-2014 | 09:31 AM
We keep our cooler under the passenger bolster (my wife never drops hers out). Ill try to post a photo of my engine compartment setup for storage.
jetskidrewski is offline
Old 06-03-2014 | 11:09 AM
Thanks guys for the help.
Jetskidrewski - I'd like to see that engine compartment storage.
Abs777 is offline
Old 06-09-2014 | 10:04 PM
Overall view and close-ups of my bilge setup.
I use the plastic tote to store the cockpit cover. Its bungeed in from the SS loop I added with through-bolts then to the trim ram pump bracket.
The lifejackets are clipped to the steering or throttle cable housings to keep them from sliding into the engine.
Old 06-10-2014 | 07:28 AM
I should be going out on steves 232 tonight after work. Ill snap a couple photo's also. The storage area by the engine on the port side looks to be OEM baja thing. I have seen it on other islanders It is justa couple 1/8" thick plastic sheets screwed down with angle alum bracket
As for Steve's cooler..... It just bounces around in the center
92nsx is offline
