incorrect volt meter >
Old 07-12-2014 | 02:12 PM
Default incorrect volt meter
I have a 2000 25 outlaw,volt meter use to read 12 volts ,now under 12 almost 10.5 .batterys read 13.6 to 14 on high idel,alt reads same,rear of gauge reads low.
stingraysx22 is offline
Old 07-12-2014 | 05:49 PM
I had somewhat the opposite - always reading higher-- it was related to checking the ground on the instrument - I loosened the nuts holding the wires and cleaned the contacts - all was well after that. .
In addition, I would check the voltage at the meter and verify that in fact it is reading the same as the battery and alternator.
good luck
3pointstar
3pointstar is offline
