-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Need help with proper drive depth on my 272 (https://www.offshoreonly.com/forums/baja/334210-need-help-proper-drive-depth-my-272-a.html)
slowdmax 02-01-2016 01:08 PM
Currently has a -2 IMCO upper and Lower. I've read the -2's are no good.
Right now the center shaft of the lower is right at 7.5 inches below the flat spot on the hull below the drain.
Before I just start throwing money at spacers I would like to know the proper depth.
For some reason It wont allow me to attach pics.
Griff 02-02-2016 01:37 AM
You can only attach pics with a paid membership or by hosting them on a photo sharing website.
That being said, 7.5" below the bottom is still very deep and you should not have any issues.
Are you sure its a -2 ??? The uppers are the same. The lower is what is shortened and it will be stamped with a -2.
class6 02-02-2016 05:36 AM
This is apples to oranges. My Pantera with a -2 Imco is 3" below. Measured with drive level to get correct height. If you want to check, The -2 from the top to center prop shaft is 8.25" for the lower.
slowdmax 02-02-2016 11:20 AM
Yep Stamped with a -2. I was going to spacer it out but thinking I will just get my prop labbed to get the lift I need
class6 02-02-2016 12:14 PM
where is yours marked?
Griff 02-02-2016 03:55 PM
I'm pretty sure Baja raised the X dim on most models over the years. What year boat is yours???
At 7.5 " below the bottom, that is still very deep and should carry the bow easily.
Running the correct prop can make a huge difference. What prop are you running??? What power???
class6 02-02-2016 06:18 PM
Is it not reacting to trim? slower than you think it should be? whats the problem ? When you say lift, bow or stern?
