Manual release for Engine Hatch? >
Old 09-23-2002 | 04:52 PM
Dock Holiday's Avatar
Charter Member #34
I am a little confused here.
The 272 and 36 Outlaw both are set up where I can lift the hatch several inches if the actuator fails. This allows you to reach in and pull the pin so you can lift the hatch on up.
Actually the 36 can be raised about a foot to make for easy access. Of course the hatch is very heavy itself.
I cannot see a need for anything else, especially for $1000 dollars?
Dock Holiday is offline
Old 09-23-2002 | 06:36 PM
digitalMan's Avatar
Default agree with dock
On my '02 model the piston is attached to the hatch with a sliding mechanism that allows you to manually lift the hatch about 6 inches. Once you lift the hatch, you pull a release pin like an earlier post described. You just have to be careful not to continue lowering the piston once the hatch touches down, or you will take up the slack in the slide.
digitalMan is offline
titoon420
Classic Offshore
8
09-15-2007 08:21 PM
good2go38
1
08-31-2006 01:40 PM
wildthing357
Outerlimits
5
05-31-2006 06:26 PM
wildthing357
Outerlimits
6
10-10-2005 11:29 AM
nd4hire
Pantera
5
09-26-2003 08:25 PM
