Hydromotive props on 33 outlaw >
Old 04-21-2016 | 10:36 PM
Default Hydromotive props on 33 outlaw
Anyone tried 28 4 blade hydromotives on a 33 outlaw 496ho's?.. currently running labbed 26 bravo's...
Taube is offline
Old 04-22-2016 | 12:38 AM
A labbed 26 Bravo is comparable to stock 24 Hydromotive rpm wise.
Hydro Q4's give a ton of stern lift. Q4X's are comparable to Bravo props but go down 1" of pitch on the Hydros.
Griff is offline
Old 04-22-2016 | 06:33 AM
F-2 Speedy's Avatar
You for sure don't want stern lift in a 33, get the nose up and let er eat................. I ran 28-4blades B-1's on my 33 ( when I upgraded power ) and they worked well, the stock 502 mags had some 25 mirage + on it but they are a Bioch to spin
F-2 Speedy is offline
Old 04-22-2016 | 11:11 AM
Yes, what everyone is saying is spot on.
The Bravo is the best option. I personally didnt see anything out of Q4X and I would almost guarantee the Q4 will slow you down.
If you start with the Bravo 1 26 or 28 BBlades can lab it to get the maximum bow lift and therefore speed.
Keith Atlanta is offline
Old 04-22-2016 | 12:56 PM
IMO, labbed 26 Bravos will be the best prop with stock power.
Griff is offline
Old 04-22-2016 | 08:47 PM
I like the rough water ride of the hydro in a 32 baja. Had them spinning in to keep bow lift.
Wilks is offline
Old 05-10-2016 | 03:20 PM
stock 26s on mine.
mittens is offline
Old 05-12-2016 | 02:25 AM
Default Spinellie prop
You should give Doug Harper a call at spinellie bros prop company. He made me a prop for my 24ft outlaw supercharged 502.
It worked excellent, he knows his ****. Tell him jj Sent you and he will take care of you
If you want to talk further shoot me and email at [email protected]
Jj
conneroutlaw is offline
Old 05-12-2016 | 07:42 AM
Food for thought
Jeff has a 2004 33 with 496 HO's . He spins 28 B1 props. Cavitates big time out of the hole without tabs. He can also bounce off the rev limiters once trimmed out. Said he talked to Brent this off season. Brent said there is no one perfect prop for the 33. He said they are all over the map. Baja must have moved the X around and played with weight is my guess. For Jeff's 33 Brent said if your on the limiters already, go to 30 B1, get some #'s and send them to him. He will tune them in.
He runs 76 on Livorsi GPS. He also runs heavy. 4 batteries, 2 full water tanks, fridge always full of water and food, tons of gear,
My 33, I haven't had out yet, but came with B1 26's hanging off the back and the guy also gave me a set of mirage plus 25's. Im guessing the 25's were the stick props.
92nsx is offline
Old 05-22-2016 | 08:33 PM
26 pitch 4 blade and let it be
dlange is offline
