496ho manifolds >
496ho manifolds
496ho manifolds
Old 03-12-2020 | 03:27 PM
Check/ remove the end caps on the main heat exchanger to check the rubber cap seals and than the oil cooler for debris, on the port side under exhaust manifold, for clog.
underpsi68 is offline
Old 03-13-2020 | 06:08 AM
Change the rubber seals on each end of the heat exchanger,when they get old they can get stretched and can block the flow of water through the heat exchanger
AusScarab29 is offline
Old 03-13-2020 | 06:45 AM
Forgot to mention that I already changed the gaskets on the sides of the heat exchanger..... ordered a new T drain with the ball check valve .... I will put it next week and see what happens...... talk to the parts guy and they no longer sell the parts to rebuild it .... had to buy the whole part for $52 ... in update as I go
Jerome is offline
Old 03-13-2020 | 07:16 PM
You can pull both hoses from the manifold with the engine running to see how much flow and if the ball valve is working.Dont run for to long with no water going through the manifold
Old 03-13-2020 | 08:42 PM
Flush it with 80% water 20% muriatic maybe you have some calcium/salt buildup.
Keith Atlanta is offline
