-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Back fender mount on 29 outlaw (https://www.offshoreonly.com/forums/baja/343961-back-fender-mount-29-outlaw.html)
FBRONCO 01-18-2017 08:48 AM
Originally Posted by iaoutlaw (Post 4520527)
Tie a knot on the bottom of the fender then figure 8 the line around the cleat at whatever height you want the fender then use the leftover line to tie up.
http://i1380.photobucket.com/albums/...pswiinoold.jpg
The back cleats on the 29 are on the transom so they don't really work well in this manor.
iaoutlaw 01-18-2017 10:03 AM
If your willing to drill a hole I would install one of these on each side
http://www.cpperformance.com/p-81923...nder-lock.aspx
BajaDan 01-18-2017 10:57 AM
1 Attachment(s)
We mounted some pop up cleats and have enjoyed them. They work great for fender mounts. If you don't want to drill holes, then get a couple of the Seasucker mounts.
https://www.seasucker.com/collection...hst=collection
I'm big on cleats so we also added another pair of midship cleats. The aft cleat was just never in the right place and if you wanted another spring line the cleat gets crowded with more than one line on it.
[ATTACH=CONFIG]563876[/ATTACH]
Griff 01-18-2017 12:40 PM
Originally Posted by FBRONCO (Post 4520507)
Do you have to worry about the loop popping off the mushroom cleat if the boat starts moving up and down on the dock causing the fender to move up and down? I would hare for the fender to come detached from the boat eliminating any protection.
I had mushrooms on my Pantera. I made the loop big enough that I would wrap it around the cleat once. Never had a fender come loose.
F-2 Speedy 01-18-2017 02:09 PM
I had some at a party once, most excellent...:bong::party-smiley-048:
Tractionless 01-19-2017 08:16 AM
Originally Posted by FBRONCO (Post 4520508)
Where do you tie the lines?
I use the loop end through the same cleat and the fender over that.
FBRONCO 01-19-2017 10:59 AM
Do you mean that you made the loop just big enough to stretch over the mushroom top and that would be good enough?
FBRONCO 01-19-2017 11:00 AM
Does anyone have a picture of one of these in use with the rope attached? I'm just worried about the rope slipping off when the boat moves up and down against the dock.
Griff 01-20-2017 01:15 AM
No, use like a 6" loop and loop it over and wrap it around the mushroom cleat. It won't come off.
FBRONCO 01-20-2017 07:37 AM
I'm sorry. I feel really stupid here. I'm just not understanding how a 6 inch loop will stay secure? Just with the weight of the fender and gravity? Seems like it could easily pop off the mushroom top. I guess I'd have to see it in action. I know when I used a boat cleat, their is no way that is going to come off. I know I could use the pin kind, but I'm not sure I like the big weight of the pin attached to my fenders when retrieving and returning the fenders to storage.
