Props turning in or out BAJA >
Old 02-22-2018 | 12:38 PM
Originally Posted by JRider
This works with XRs, I dont think it works with standard Bravos.
it works with regular bravos too, they’ve not rotation specific
JaayTeee is offline
Old 02-22-2018 | 01:44 PM
I would like to agree with you but I can not' on mine. My bravo one drives do not have straight cut gears. Bravo XR drives do. Mine have standred bravo one gears that are like helical, but I think the right name is spiral teeth. Runing them in reverse at high rpms could be really bad
Lou.Slater is offline
Old 02-22-2018 | 05:04 PM
It has nothing to do with straight or helical gears, they all rotate the same internally, they're in constant mesh with the pinion gear which connects to the engine, they don't switch directions when shifted.
The top driven gear, when engaged by the clutch, turns the prop shaft counter clockwise,
the bottom driven gear turns the prop shaft clockwise when engaged by the clutch.
All bravo lower gear sets are straight cut, they have no problem rotating one direction or the other.
JaayTeee is offline
Old 02-22-2018 | 05:13 PM
Thank you for everyone's advice I do appreciate it.
Old 02-22-2018 | 05:24 PM
I stand corrected, I didn' think about that way. Your are right. Thank you. I might try it once with spinning them in to see how it handles. I over looked that part. Being I'm a farm boy I should of thought of that. Thank you for your help.
Old 02-23-2018 | 05:52 AM
Quinlan's Avatar
So where do you boat? and we need some Pics
Quinlan is offline
Old 02-23-2018 | 06:26 AM
How do you put pics on?
Old 02-23-2018 | 06:28 AM
I boat at lake Michigan around Muskegon and Grand Haven, and lake Saint Clair. I cant figure out how to put pics on here.
Old 02-23-2018 | 09:25 AM
email them to me, you need to be a paying member
JRider is offline
Old 02-23-2018 | 11:42 AM
My neighbor Lou dog and his noisemaker. The neighbors either love or hate us.
Attached Thumbnails Props turning in or out BAJA-20170909_115925_resized.png   Props turning in or out BAJA-20170903_084051_resized.jpg   Props turning in or out BAJA-20171023_062751_resized.jpg
Props turning in or out BAJA-20170903_084113_resized.jpg   Props turning in or out BAJA-fb_img_1504480761116.jpg   Props turning in or out BAJA-fb_img_1504711006564.jpg
Props turning in or out BAJA-fb_img_1504710995406.jpg   Props turning in or out BAJA-fb_img_1505058703458.jpg
JRider is offline
