Water pressure sensor
Hi all- anyone have any thoughts on the water pressure sensor, can they be cleaned or do I need a new one? Last time I ran it went off. thanks in advance!
In my experience the problem has always been the wiring harness/connector not the sensor. If this is a twin application you could swap sensors and see if the problem follows the sensor.
John |
First and foremost lets ask what type of sensor are you talking about OEM Merc for PCM 555 / ECM 555 or ?
Merc oem water pressure sensor - that sensor can go bad and some are bad right out of the box. you can clean the hole out and try to see if that helps. I always do as well to see what takes place Also poor grounding does not help for its location RFI and EMI knocks the sensor out as well. spark plug wires and so forth |
