1996 Baja 270 Start Replacement
I need to replace the starter on my 1996 272, looks like I'm going to have to pull the engine to do so. The starter bolts are against the flywheel guard. Can only get an open end wrench on the outer bolt, but can't turn it because of the stringer. Bummer. Any of you experience similar problems on this year model.? I've been looking at the Mercruiser online parts catalog, and if I can reach the smaller bolts at the bottom, I may be able to drop the flywheel cover off and then access the starter bolts that way. What real purpose does the flywheel cover serve anyway, other than keep floating crud out of the flywheel. You've got a real problem if the bilge water level gets that high.
I talked to a friend last night that had a 2000 270 and he said his was fairly easy to get too. Bummer.
Charter Member #1171
You need a swivel head ratchet,,,, it can be done.!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Its doable .....PITA but doable ...I did mine last weekend in my 252 , same boat pretty much. When I worked at Baja dealer did a bunch of 272's never had to pull a motor . The worst part is standing on your head for 2 hrs. When I bought mine could tell it had taken on water and sat in a lake without a working bilge pump. Water line in bilge was over the starter. The previous owner wasn't too brite. Starter was iffy all season. I replaced the slave on top of the motor first also just to make sure. On starter wires I cleaned all connections with sandpaper. Then sprayed with battery corrosion preventive. Hopefully no more "click" issues.
I think I will be "modifying" my cover before I put my motor back in.
