1997 Baja Outlaw 32 thoughts... >
Old 03-25-2020 | 03:57 PM
Default 1997 Baja Outlaw 32 thoughts...
Thinking of purchasing a1997 Baja Outlaw 32 it has fresh bravo 1 drives with full external hyd steering and mercruiser 502magnum mpi engines rebuilt about 100hrs ago, also has Quad bolsters not sure of props but they are 3blade whats everyones thoughts on the boat my last one was a 1990 checkmate convincor gtx
what size fuel tank does the baja have and does anyone know about what cruise speed should be and top speed i know without knowing what props i have its just a guess
SRTPWR is offline
Old 03-25-2020 | 04:21 PM
F-2 Speedy's Avatar
I had a 33 OL 2000 model and is was a great boat, never been in a 32, it will be a bit cramped with the quad seating, 502 mag mpi's are great engines, make sure you see the receipts on the rebuilds, my 33 had 180 gl tank, cruise about 50 top out around 65 is propped correctly and engines and drives are performing well, dont buy it without a survey and test ride, and check to see if you can get it insured
sorry not much of mine is about a 32...............check for moisture transom and stringers.......good luck
F-2 Speedy is offline
Old 04-06-2020 | 04:50 PM
Try insurance with Allstate, no inspection. My '96 302 (and trailer) is insured with them for $600 yr. full coverage with agreed upon value of what they typically sell for.
Tractionless is offline
